On any car of great worth, I believe that it should be insured comprehensively, rather than at market value. A GT-R will be such a car.
On a car worth less than $10,000 but above $4,000, I might be tempted to insure it at market value - but maybe not.
If the car is worth less than $4,000 I might only pay for third party property insurance.
Sum Insured/Premium ratio depends on too many variables.
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6911463
Well I have a 93 R32 GTS-T coupe. Insured for $11,500 (most I could get it insured for)
I'm 21, lost my liscence once before and I'm paying $866 a year.
With JustCar Insurance.
Hope this gives you a rough outline.. :)
Edited by Zrobe
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6911573
so comprehensive insurance would be insuring it at an agreed amount?
how much did u insure your car for Terry?
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6912227
Agreed value can be a bit of a personal question for some, me included.
I could be wrong but the rarer and more valuable the car, the less likely people are to disclose.
Feel free to prove me wrong.
oh... ok
no worries then. was just checking out to see how "insured value" relates to "annual premium"
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6913536
Generally speaking the greater the agreed value, the higher premium.
In saying that, the bulk of the premium often relates to the type of car (GTR=high risk), age of driver and suburb its garaged. Suburbs can make a pretty big difference.
Insurers will also increase/decrease premiums based on their experience as well as the types of risk they want to insure.
Years ago nrma jacked up my premium on a 200sx from $2.5K to over $4K. No change at my end. I went in to talk to them and the lady said that instead of saying no they will sometimes increase premiums significantly for cars they don't wish to insure.
I went elsewhere.
Edited by Cherry Racer
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6914175
ok maybe i should rephrase...
if your car is rare and valuable, are u able to insure it accordingly to how much u paid for it...mods and all? or will the insurance company tell u how much its worth?
Heavily depends on the company offering the policy. The majority of mainstream companies will probably exclude highly modified cars, let alone insure them for an inflated sum.
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6915010
think i came across a company that specializes in insuring jap imports, cant rem name though... anyone knows abt it?
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6915071
A lot of the younger generation (myself included) tend to insure with just car insurance, if that's who you're thinking of.
Shannons and a few others I can't name off the top of my head offer decent insurance too (In terms of recognizing import, rare or collectable cars and modifications) but unless you're 25 years or older they won't cover you.
https://www.sau.com.au/forums/topic/427875-insured-amount/#findComment-6915329
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
