to be honest, I am running a 3.5" RSR down pipe and a 3.5 -> 3.75" HKS Super Dragger and it's quieter than any RB I've heard.
Ph@t G's car is loud as fek, and it's only got a 3" system, that being HKS Hi Power exhaust
Prior to my current exhaust, I had a ling long spec DRIFT cat back, it was disgusting loud and was also 3"
  • Replies 47
Give me this or i kill you! :P
nawwwwwww won't fit your car :)
big pipes!!
There's a nismo cat back i'm looking at that came off a BNR34. Will it fit onto my GTT without modification, or is the underbody completely different?
not sure about R34 GT-t, but the exhaust I'm using is from a R33 GT-R
So the exhaust from a r33 GTR will be a direct fit onto the GTT?
Saw a cheap X-force 3" cat back coming off a 33 GTR. Will i be able to fit it on my GTT?
nawwwwww
R34 GT-R will fit on R34 GT-t (according to Mat)
R33 GT-R will fit on R33 GTS-t
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
