Price dropped to only $19,000
Don't buy a stock standard Skyline! Within a few months you'll regret it and be looking to modify and upgrade. Buy this Skyline with the major mods already done and save yourself over $15,000 in parts, tuning and modifying. This car already has everything done and is priced cheaply for a quick sale of $19,000 ono.
5 speed manual
1993 wine red
90,300kms
Rego until 09/04
Interior:
- Keyless entry with alarm and immobiliser
- Automatic Turbo timer
- Factory extra Skyline floor mats
- Apexi AVC-R electronic boost controller (blue screen) stealthily installed in dash
- C's short shifter gear box (reduces throw by 30% - feels fantastic!)
- Mugen racing shift knob
- 'Skylines Australia' club seat covers have been on to protect mint condition seats
- New leather gear stick and handbrake covers installed recently
Exterior:
- Nismo 400r front bar and side skirts (provided with car)
- Series 2 rear wing
- 17" wheels with low profile rubber
- White light headlight globes
Handling:
- Tein type HA fully adjustable suspension
- Cusco front and rear stabiliser bars
- The car handles beautifully, sticks to the road, come and drive it!
Performance:
- Hybrid Front Mounted Intercooler
- Apexi Power FC computer professionally dyno tuned (with Hand Controller)
- Apexi AVC-R electronic boost controller(low = 10psi, high = 12psi)
- Heavy duty clutch with 30% increased pressure plate
- Full turbo-back Nismo 3 1/4" exhaust with 7.5L highflow CAT
- Pod filter with cold air intake box
Sound:
- Sony mp3 headunit with remote control
- Pioneer splits up front
Lovingly maintained. Change oil every 5,000km and plugs every 10,000km. Drives beautifully, come and try it. Power is 197kw at rear wheels or approx 300hp engine. Call Craig on 0416 212 290. Cheers.
https://www.sau.com.au/forums/topic/42811-clean-and-fast-r33-gts-t-sydney/
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
