Ok, so my ps3 has been playing up a bit lately and it keeps coming up saying data is corrupted and has to restore. kind of getting over having to do it every few weeks so I'm thinking I'll just get a new hard drive. I reformatted it a while back but it was still not right afterwards.
so what I would like help with is choosing a new drive, and where to get them from for a decent price. I currently have a 250gb in there and I have plenty of room left on it. I don't have many games that I play so I still have plenty of room on it, so size doesn't really matter. price matters more
https://www.sau.com.au/forums/topic/428201-need-new-hard-drive-for-ps3/
pretty sure most people use SSD's these days. but pretty much every 2.5" SATA hard drive will do the trick, just stay away from hitachi and western digital green drives if your going for a hard drive. people dont seem to like the Samsung 840 SSD, but mines been running fine for some time now.
i use 2 places to get my PC gear from, PC Case Gear is one, but their freight can sometimes be pretty expensive. the other one i use is Megabuy, they work out about $3-4 cheaper on some items, but they use Star Track Express ( i personally favour them).
http://www.megabuy.com.au/wd-wd7500bpkt-scorpio-black-750gb-25-sata-hard-drive-p257136.html
http://www.pccasegear.com/index.php?main_page=product_info&cPath=210_267&products_id=16837
I thought the ps3s had problems with ssds??
I bought a 500gb from d-comp.
just ask your local computer shop.
The only local computer shops I can get to are dick smith (they know nothing) or harvey norman (they are ok, but don't keep much stock of hard drives) because of work. I leave for work at about 7:30am and get home after 6pm, so that narrows my options down a bit.
Buy online. I got mine from Mwave.com
something like this would probably get you by if your not interested in having rediculous amount of space. Slightly faster then standard and slightly more storage. But then you can go cheaper still if you want to stick with 250gb and/or you dont want to bump the speed up to 7200rpm
http://www.mwave.com.au/product/sku-aa20468-wd_scorpio_black_320gb_25_satsii_7200rpm_wd3200bekt
They don't necessarily have problems, but the benefits of a SSD aren't recognised as much with the PS3.
Comparison videos and reviews of using SSD in a PS3 and most of them will conclude that it's a waste of money.
Update: did a format in the old drive last night. Installed my games this morning. It was playing up a bit still. Restarted it and it wouldn't turn on. Lights came on but no-one was home. Wouldn't even boot in safe mode, etc. turns out I'd bought extended warranty when I bought the system and there was still about 2 years left, so it should get fixed/replaced for free.
That's Good News ,I just hope it doesn't take them 2 months to fix it
my mate who runs the place I bought it from said that the last one they had an issue with was just replaced without them even having to send the old one away (he then took the old one out to the local shooting range and blew it to pieces), so fingers crossed. he said mine faces the same fate if it gets replaced, lol.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
