Is 330rwhp a good power result on r33 gtst with the following mods-
-powerfc
-forward facing plenum an 80mm throttle body
-walbro fuel pump and pressure reg
-fmic
-top mounted ball bearing turbo
-external wastegate with screamer pipe
-3 inch exhaust
-standard injectors and afm
-running 16psi
https://www.sau.com.au/forums/topic/428864-330rwhp/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
