which year/s are the series 3 models?
I seriously wonder how people found out answers to questions before the internet existed when now that we have the power of this awesome tool, people still can't be bothered......
http://lmgtfy.com/?q=v35+skyline+wikipedia
If you read it carefully you would have notice it mentions three model updates.
S1 = 2003
S2 = 2004
S3 = 2005
The coupe was one year behind in these updates, so +1 to the years above,
Alternatively:
http://www.jlimports.com.au/nissan-skyline-350gt-v35-coupe
Again, google is your friend of yours. Laziness is not a friend of mine.
Clearly Laziness is......because its wrong according to the two issues over hyper rev I have and Amamaya.
series 1 are 2001-2003MY series 2 is 2004-05MY and series 3 coupe only was 2006MY
they did updates every 18 months - 2 years.
no wonder this group gets the reputation of being called v-tards
Edited by Howaitonaito
Coupe wasn't released until 2003 - retard.
Back to bolting shit panels to average cars for you.
S1 = 2003
S2 = 2004
S3 = 2005
Alternatively:
"the coupe was one year behind these updates, so +1 to the years above", implying that you are talking about the sedan being the only other shape in the V35 series?
Correct.
so to put it more simply for you.
Sedan:
2001 = released
2003 = update
2004 = update
2005 = update
Now as I said before (and as you have quoted), the coupe was +1 year behind these updates - but obviously not released until 2003. So......
Coupe:
2003 = Coupe released (S1)
2004+1 (2005) = Coupe updates (S2)
2005+1 (2006) = Coupe update (S3)
The specific differences of each model year are detailed in the link I posted here:
What do you want? Another lesson?
How about.....a lesson on the difference between facts and opinions?
Facts are statements that are irrefutably correct and supported by empirical evidence. Example, the things that i wrote above which you said we're incorrect so I directed you to some sound sources of evidence to prove my statement - thus making them facts.
Opinions are subjective statements belonging to the person expressing them, open to discussion or justification should the person choose to do so, but ultimately will have no right or wrong answer.
I'm not going to waste my time proving how putting stagea panels on a skyline sedan looks shithouse, despite you having kindly supplied supporting evidence - ergo, a 'fact' - so i guess we will keep that in the 'opinion' category.
That concludes today's lesson.
Okay then here is my opinion:
-You precious white coupe is nothing special.
-try getting coilovers or lowering it, uour passengers get sea sick.
-Your a deadset waste of space and was clearly dropped at birth.
All bow down to the new leader of the V-tards....you may all kiss his ass!
All this coming from a SAU VIC member.......tsk tsk tsk
Asshole
Ahh yes; because the internet is the last bastion of factual information. :rolleyes:
If you are implying that a car importer (essentially a used car salesman) can be held up as an irrefutable source of facts relating to cars; do I have a deal for you!
My very good friend; I would like to tell you a story about my brother who, as it happens; is a Nigerian Prince! He would like to share his immense wealth, and give you 17 million dollars! :yes:
There are however a couple of small things you will need to do to help him. :whistling:
I could spend 5 minutes on the internet and give you such facts as;
1; You can charge your iPhone in under 30 seconds, simply by putting it in the microwave!
2; All pizza delivery guys end up screwing incredibly hot women, who never seem to have enough cash to afford home delivered pizza.
3; "Liking" things on Facebook CAN CURE CANCER (also helps with poverty).
4; Will's & Kate's baby is a newsworthy event.
EMPIRICAL EVIDENCE! :woot:
Stop it.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
