Where in Perth can i get permits for my mods, and because i have permits does that mean its foolproof for when cops decide to pull me up and try and give me a yellow, please bear with me as i dont know much about about Perth laws as back in NZ you can put pretty much anything on your car and get away with it,..I cant afford to be yellowed as it will f**k me up for work
https://www.sau.com.au/forums/topic/429232-permits/
depends what it is,
i am going through engineering for my build at the moment, but its a 2.8 with a big single, half cage, suspension & brake mods.
but
you need to submit the paperwork to DOT and they will respond with approval in principal. then you engage and auto engineer who sorts it all our for you.
http://www.transport.wa.gov.au/mediaFiles/LBU_F_VS_ModificationLightVehicles.pdf
https://www.sau.com.au/forums/topic/429232-permits/#findComment-6945199
depends what it is,
but
Would DOT really approve of this, street driven?
My 32 is not running and I'm scared of even letting the rego run out haha
Edited by Zrobe
https://www.sau.com.au/forums/topic/429232-permits/#findComment-6945232
The mods i have carried out so far, are 3'' turbo back exhaust with hi-flow cat, adjustable coilovers, front mount intercooler, BOV, Pod filter and 18'' rims.. I just want permits foir those mods to prevent a yellow sticker, or do you guys think i can still get one even with permits?
https://www.sau.com.au/forums/topic/429232-permits/#findComment-6945296
Well I'm in QLD and when I transferred the my r32 gtst into my name, pretty much same mods as yours
They didn't look over the car or anything.. But I wasn't re-registering.. So yeah different ha..
I can say no to pod filter.. That won't pass. (Unless its secured??) but stock air box is better anyway..
Edited by Zrobe
https://www.sau.com.au/forums/topic/429232-permits/#findComment-6945303
they have sent me a letter for approval in principal, so yes
i just need to pass an emissions test, noise test, brake test (E85 and a "custom exhaust" will take care of that ;) cant have an external gate
https://www.sau.com.au/forums/topic/429232-permits/#findComment-6945702
Do you mean can't have an external gate venting to atmosphere? Or no external gate at all?
https://www.sau.com.au/forums/topic/429232-permits/#findComment-6946026
Cant have external gate venting to atmo, untreated exhaust gas = big no no
Yeh this is obvious; Hattori didn't specify though. Just said no external gate. I was quite sure a plumbed in external wastegate is fine, though I haven't been through the process myself, so just wanted to clarify.
https://www.sau.com.au/forums/topic/429232-permits/#findComment-6946450
I bought my skyline over from NZ and it had pretty much the same mods. It passed the pits, I got the permits and havent had any problems.
https://www.sau.com.au/forums/topic/429232-permits/#findComment-6954073
have you been pulled by cops yet?.. i wish i brought old skyline over from NZ, i spent thousands on it but didnt realise i could.
https://www.sau.com.au/forums/topic/429232-permits/#findComment-6958547
You need to get a copy of the rules from DOT for modifications that are legal. Some people mistake permits or engineering certificates for a "do what I like and get away with it" permit. For example, if you lower your car to 2cm off the ground, you will never get a permit or engineers certificate. You need to mod within the rules as well. Just something to keep in mind.
https://www.sau.com.au/forums/topic/429232-permits/#findComment-6964988
  • 3 weeks later...
How have you got a permit for your adjustable suspension? i got a letter of approval in principal but its saying I need to have 1/3 of the original suspension travel and a engineers report. There is no way the BC coilovers are going to have 1/3 of the original travel. I've started the hunt for standard suspension to get over the pits
https://www.sau.com.au/forums/topic/429232-permits/#findComment-6996179
    • You've got yourself a good old game of have fun. That shit is annoying as hell to remove. Thankfully for you, yours is on metal, most of the stuff I take it off is plastic, so typically hear guns are out. I normally end up continually dragging my thumb with pressure over it to get it to peel up. Eucalyptus oil then works well for getting residue and last remnants off.   Edit: plastic scraper might be worth while too. One that'll dig into the foam tape, but not scratch the paint.
    • So I ride and race motorcycles for fun and have always used a van to transport my track weapons. Figured towing a racebike with a skyline would be different and if done right could - "look fully sik" or quite cool for us grown ups lol. Pic of yours truly on two wheels I also have a trailer already kitted out to transport my bikes ...and I have a spare set of rims that match the car that I was going to rebarrel to get deeper dish at some stage but they have just been gathering dust. Sooooooo it is only logical.... Stay tuned !!
    • If by "flap disc" you meant "chocolate wheel".... then they are OK for getting off stubborn remnants. But not for stuff with bulk depth. If by "flap disc" you meant "abrasive paint f**ker"....
    • Beauty, thanks guys, got some ideas now. I note that none of you agreed with the flap disc so that's good to know. 👌🏻
    • I had small pin holes in my glazing putty but didn't want to put more putty to not make a mess again and I put 2 coats of epoxy primer to prevent it from rust. Though you can only see the pin holes if your eyes are almost against the panel. Do you think when the 3x coats of high fill 2k primer and 2 base coats go on that it will be visible?
