I have a set of RAYS VOLK Racing - TE37 for sale
18" x 10.5" offset +15
Colour: gloss black (factory painted)
Holes: 5H x 114.3
Weight: 8.8kg (super light)
DOM: 26/10/09, done less than 9,000km
Condition: 3 wheels are perfect, 1 has slight gutter rash, but being black, can only be seen closed up
High performance RAYS VOLK Racing wheels in the TE37 style.
The TE37 style has become an enthusiast favorite, being the lightest Rays wheel for street applications combined with aggressive looks.
Forged 1 piece Wheel
Made in Japan
$3200
https://www.sau.com.au/forums/topic/429290-rays-te37-18x105-15-blk/
Pretty sure Adelaide
thanks
my offer still stands if interested
thanks for the offer
If these are still around in a couple weeks ill be in contact. Any photos of the rash on the one wheel?
close up photo is the last one before the white car, click on the photo and zoom in, you could see the rash
Price is $3000 delivered Australia wide
or $2900 pick up/ your own courier
Note that these are original wheels with original factory paint, not refurbished/resprayed
19s have the "dish" you are referring to mark.
Anything below a 19 will have concave.
These are the most concave you can get in TE37s.
Andy, don't budge on the price, or i'll come down and slap you :whistling:
^^ Thanks
:wub:
Also location would be great
Adelaide, SA
Had 3-4 ppl PM me asking for the location,
I had "SA" in the title... but they can be delivered to your doorstep with insurance
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
