Hi searched and searched overwhelmed with everyone with an opinion need a strait answer. I want to lower my v35 1.5 inch. What camber adjusment arms will i need
1.rear camber arms?
2 rear lower control arms
3. front camber arms?
4. rear toe arms?
5. camber bolts?
Is rear camber and toe controlled of the same arm?
What brands are good. Heaps of unamed brands on ebay. any good?
If i buy this kit will i have everything i need
http://www.ebay.com.au/itm/Nissan-350Z-Infiniti-G35-Front-Rear-Camber-Control-Arm-Adjustable-Kit-Blue-/261252599572?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cd3de4f14
Please dont make this confusing.
thanks and yes i know its coverd in a million post but its get so confusing
I am fairly sure those items are all you will need to get your camber correct with a 1.5in drop. Although I am a bit suspicious of those front arms which claim up to +3deg positive camber. The best have seen is +1deg before the arms are too long and hit the guards, then shims are added to the hub to obtain more than 1deg of positive camber.
I don't think you will have any issues pulling the rear toe into spec with just the rear camber arms (but maybe someone with a 1.5in drop can confirm?)
I have approx. 1in drop on my sedan (350z springs), and was able to pull the rear alignment into spec with the stock arms.
A little more camber from a slight drop isnt worth spending 1K on adjustable arms. You can still get the alinement in spec without them roughly.
As long as your toe isnt all over the shop you wont be chewing tough tyres in weeks (unlike that time I chewed through a set in 2 weeks on my s14 because I had liek 20 mm toe out :P ) yes you might not get 50,000 km out of a set of tyres but even my car with all stock arms and lower easy 2+ inches (just tucking tyre with streched 19's ) and stock arms with 3+ deg camber coulds get toe to a aceptable amount has done 10 000KM on 2nd hand tyres without chewing them out so a new set + getting them flipped once start to get some camber wear shgould still last a decent time
I'm into this question too....Need more info here. I'm purchasing a set of Bc Br and want to get cambers and sway bars. these items i found on ebay looks like a steal at that price. apparently Godspeed is Tanabe rebranded and more good than bad from g35driver.com. What you guys think ??
http://www.ebay.com/itm/GODSPEED-350z-g35-suspension-sway-bar-front-camber-rear-toe-arm-rear-camber-/300803383628?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AG35&hash=item460947614c&vxp=mtr#vi-ilComp
I would be careful buying ebay parts like arms and stuff, you get what you pay for ie theyre not crash hot and the bushes they uae are crap compared to if you spend 50-100 more.
Also shipping from the US is bloody expensive so i would try and source something from japan.
Our cars take all 350Z suspension so try searching that for a broader choice range.
I have coilovers in my V35 sedan and it was slammed (my lower control arms and subframe pulled reflectors out of the road) and it had so much camber i didnt need to buy camber arms.
BC BR coilovers as scotty said are great value. Most of us run then you can get em from just jap for 1399 i think with free postage. And that will lower the car 1.5 without even adjusting them.
yea i have read several reviews on g35driver.com. Majority have complimented these items as best bang for buck. Of coz I'm in no position to compare the Godspeed swaybar / camber kit with other brands like whiteline, cusco, eibach etc... but since i dont track my V, all i've wanted is just having a good looking street car with sweet drive :D. I also agree BC Br is a really good option.
Question: anyone knows somewhere to install coilovers , swaybars and camber in sydney for a good price/quality ??
Think of it like this. If you spend up big now chances are you wont have to spend much later. Spend little now and then send more later because the little you have spent has broken/failed. Think about it.
What would you buy a kogan TV or a Samsung TV?
Same thing.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
