I installed a Bosch 910 pump over the weekend, car was running fine after a test drive.
However on the way to work this morning the car stalled at the first intersection, and wouldnt start again.
After getting it home I pulled everything out to see what the problem was. I found the pickup had fallen off and was somewhere in the tank. I couldnt feel the bugger anywhere so decided to give up and let a pro do it.
So I get a call from the workshop today and they tell me that I shouldn't have used it internally, and that it was very dangerous?
There are allot of people using these intank, is it safe to use?
I was running a Bosch 910 in-tank up till the end of last week. It had been in there for almost 4yrs and came out still in tip-top shape. It's now going into an RX7 turbo circuit car. The only reason it was replaced was due to it not handling the demand placed on it.
EDIT: Didn't read your above post until after I'd added the below info....
How is a Bosch unit any less safe than the stock pump is replaces? They both require power and earth connections and unless I'm mistaken they both have the same kind of construction. If it was an unsafe practice then A LOT of workshops are up for serious legal issues!
Mine has been 8 months i think.. i think you stuffed the pickup mate :D its got to go in exactly the same position as stock and erm, not fall off. How much fuel you have in there?? Even if the pickup has fallen off, if you have 1/4 of a tank it should just suck straight in as when the tank is full its fully submerged
Shouldn't be too hard to find.. during daylight with a torch could see inside most of the tank. But i do have skinny arms. ]
Did you use a hose on the end to extend the pickup and get the placement right? Some rubber can go funny with petrol and expand, releasing the item - hence the hose clamps tight as buggery
Wouldn't be dangerous.. might stop working yes, dangerous no.
Had about 1/3 a tank and yep I had some hose on the end (was using your pic's as guide) and that was still attached when I pulled everything out. But come to think of it, it was a little out of shape, so maybe I bought the wrong hose... Silly me!
I didnt want do it up to tight as the end of the pickup was plastic and didnt want to break it with hose the clamp.
Dunno whether to try again with the Bosch (and your help) or get a GTR pump?
Hmm, well I'm confused?
I have an '0 580 254 910'.
He said I need an '019', for in tank applications, and this was apparently confirmed by someone at Bosch too.
:confused:
Edit: According to http://www.bosch.com.au/sat/motorsport/dow...s/fuelpumps.pdf there is no 019.
Many things aren't used for their intended use.. but work fine.
Many have no issues, and many follow the manufacturers guidelines a little too heavily. More to the point, they probably would prefer you to pay the extra for the intake one.
Many people say "yes" and many say "no"... but whatever works works. It worked for me, and seem a few others on the forums here.
But if you feel safer with a GTR or the intended "intank" one, change it for one of those.. i'll help you install, now you know how to do it that is most of the work done.
The issue here i don't think was the pump failed due to being "intank" or not at all anyhow, it was the pickup falling off.
p.s. i'll buy your stock pump in a month or so too :D
Its all good!
Apparently earlier pump models e.g. where not supposed to be used in tank at all. But newer revision models are fine for in tank applications.
The workshop was going off old info from previous models apparently? Or maybe there just covering there ass? Anyhooo I'm sticking with the 910. But my pickup is lost in tank blackhole :)
as long as you run over 1/2 a tank all the time, you should be right until you can have some time to find the pickup. With a torch you should be able to see inside. There is a small indent where it is meant to sit inside, maybe its sitting down the bottom of there?
No luck unfortunately, I've jammed my skinny little arms all the way down as far as I can, the workshop couldn't get it either.
They said I can get Bosch specific pickup that will fit on their pump correctly anyway ;)
I was running on an 1/8 this morning, so they must have put some form of hose pickup on the end.
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
