Just wondering as i am about to purchase a few of the apexi blue screeny things like safc, avcr wondering if anyone here has them and has had any trouble with them? is it a matter of simply where they are placed or they are gonna get yellow sticker no matter where u put them? cheers miles
also how ****ing long does it take nengun to reply? any other way of contacting them?
https://www.sau.com.au/forums/topic/4294-are-these-yellow-sticker-material/
but man check out the power killer ts getting out of his with the fc he has the same turbo as urs and hes got a avcr and a full exhaust system and u wanted 300rwhp and thats what hes got so its the go.
pffffffftttt blue screens hi my na is miles and im a girl that loves pretty blue screeens oooooooohhhhh
hehehehehe :lol: :shake:
Guest KILLER-T
If i were you i would buy a Power FC that was the best thing i ever got for my car. If i ever did another Skyline up again a after market ECU would be the FIRST mod on my list.
And as for the blue screen fettish you have i am the same once i have a commander screen of my own i want to pull it apart and put blue LED,s in it so it matches the AVCR screen:p
Why dont you line up 3 Blue screens so its easier for them to be stolen :lol: :lol:
Subtle is good Wassabi also if u have a SAFC within reach u or someone else is likely to "play" with it and could cause "BANG"!
A powerFC is a full computer and u have alot of maps to adjust to get the car to run as good as it does with standard ecu. The one thing i like is u can put knock sensor as your ecu check light so if u get pinging the light flashes. :-)
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
