Hey people
Im new to Australia and looking at doing a few things with the car BUT i hear everything fun is illegal over here!
EG im looking at single top mounting, adjusties now ive been told a engineering cert is needed for these BUT can still get defected if the fuzz want to!!!!??????
Can someone please give me the honest answer to how things work!! car is r32 gtr!
https://www.sau.com.au/forums/topic/429444-new/
If the highway partrol officer thinks its illegal he will still defect you.....they have no idea what the engineering certificate covers at the time of pulling you over, you may have added more (either to his knowledge or not). Even a blue slip station (pretty sure you still have t go through them to get defects 'lifted') wont give a shit if you have an engineers certificate.
I had to get defected exhaust quietened, when I went to the blue slip guy first thing he asked was if I had a engineers certificate, I said no. He told me they aren't worth the paper they are written on....basically if he ddint like what he saw he wouldn't lift a defect, regardless of having a engineers certificate. He suggested I quiten it first then come back to get it lifted. I put my stock muffler back on and went back and had it lifted. He was happy I was happy.
If you don't drive like a dick on the road you'll have no worries to a certain degree, there are plenty of opportunities to thrash your car at the creek mate, off street drags on wed nights. drifts on Thursday nights, 2 hours out of Sydney is wakefield, and marulan. why you want to stand out even more in an already discriminated crowd is beyond me. just makes it harder for the rest of us.
also, cops deserve respect mate first and foremost. think about it if your at the pub and someone comes up and gives you shit first-mouthing off etc, your going to give them shit back right. if they didn't your mood (as you say) completely changes to be non aggressive back. something to think about ay??
https://www.sau.com.au/forums/topic/429444-new/#findComment-6953044
i agree with you as in... if we all drive and behave sensibly, the cops wont make things difficult for you. its common sense and perfectly logical. act like an ass and u get treated in kind...
BUT...
".basically if he ddint like what he saw he wouldn't lift a defect, regardless of having a engineers certificate."
that doesnt give the cops the right to act as god... to abuse their authority. whats the point of decent, law abiding people paying good money and obeying the law to get an engineering cert etc doing everything by the book and yet have that thrown out the window simply cos that particular cop was having a bad day???
https://www.sau.com.au/forums/topic/429444-new/#findComment-6953093
BUT...
Yes actually it does, they can do what they like if they deem it a defect or feel its unsafe! We got a defect on a fkn Landcruiser FFS!
Your attitude will certainly help in terms of the punishment but you modify a car against the specific laws and you will end up paying the price eventually!
https://www.sau.com.au/forums/topic/429444-new/#findComment-6953150
couldn't agree more
you have taken what I said out of context, "basically............eng cert" is what the blue slip station told me. they are not police. they are independent.
look im not trying to piss people off, this is just what I was told by the blue slip station. as for the police they defect you if they think something isn't right with or without a certificate. say you got your eng certificate two years ago, well that gives you two years to make a whole heap of changes.
as they say "the nail that sticks out gets hammered"
https://www.sau.com.au/forums/topic/429444-new/#findComment-6953395
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
