Traction Tyres have been really good for all my suspension work, both the GT-T and R
the installation i would imagine can be done anywhere, but the alignment is what you want to make sure is done properly.
Traction Tyres is in rowville, but probably only 30mins from moorabbin. Straight down north/wellington rd, turn left at stud i think, right into Kellets. you're there.
They look after a lot of SAU cars
car tech in dandy for alignment or the above ^
install it your self ?
unbolt oil lines, cut the hard lines then loop an oil hose on it, remove rods from hicas rack by clamping it on a vice bench and removing with a big shifter .
install rods on lock bar, bolt it up , top up power steering oil and get an alignment
Edited by Dan_J
Yeah I wouldn't recommend doing it unless you're not too far from a tyre place that can align it... When I did mine my Rear Tow was out by something like 25mm? Not extreme, but not great for tyre life either ;)
If its aligned by eye, it should be drivable to get it done properly... Problem is most of the ebay ones are a bit out, most aren't 100% the same...
It won't drive straight until I get it aligned though will it? So it'll be a pain to get anywhere to get it aligned
its not that bad. its a funny feeling though when its all out of wack. just drive it slow.
If you want it all fitted up i think racepace supply and fit and they are top quality bars from what i hear, nice blokes too
Most of them have got a basic jig made up, they hook the two brackets over pegs measured out at the right distance, lay the bar across it and get welding... Normally the brackets are a mm or so out in a random direction, but because of the pegs the bolts still fit fine, and the variation can be adjusted back out with an alignment.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
