selling my 1992 r32 skyline, need the cash to travel and moving to a island when i get back so no real point keeping it, although it will be missed. its had a bit of work done to it nothing internal all bolt ons but still goes alright with a super clean look to it. Just finished putting in a imported engine, still rb20 but only done 110,000 on the engine itself the car has (will put up tomorrow) but haven't had anything major happen to it other than the alternator which is now a rb25. bit of damage on drivers door from a hit and run was so devastated when i found what had happened. i'll cut it sort to what mods it has and cons.
rego:
KKR 430 turbo
turbosmart eboost2
blitz ecu chip
simens injectors
billet twin feed fuel rail
saed fuel reg.
HD full faced clutch
NPC lightened flywheel
intercooler
trust BOV
upgraded fuel pump
splitfire coil packs
exhaust
HID lights
oil cache
remote start ( gets lots of attention haha)
viper car alarm and central locking
k&n pod filter
and body kit with pearl flec paint job
sound system with dvd screen
nismo interior
short shifter
switch to isolate BOV to switch to flutter
lowered
18" rims
tint
list goes on but these are the mains. have a full folder full of receipts.
cons:
pearl flec has a little de-lamination happening mainly on the bonnet and boot
drivers door from hit and run
front kit is a little how you going but still looks ok
needs new break pads but should be right for a while all are shown in photos
great clean looking car really don't want to sell it to go to a beat up old camry haha but needs to be done :(
************will upload a bit more info tommorrow and day pic's **************
$6500 ono
give me a call or tx for viewing or if you want any more information on 0423456426
cheers,
Kieran.
https://www.sau.com.au/forums/topic/429647-r32-gts-t-for-sale/
  • 5 weeks later...
Sold ****** sold ******** sold********* sold***********Sold ****** sold ******** sold********* sold***********Sold ****** sold ******** sold********* sold***********Sold ****** sold ******** sold********* sold***********Sold ****** sold ******** sold********* sold***********Sold ****** sold ******** sold********* sold***********Sold ****** sold ******** sold********* sold***********
