just putting this out there:
I have access to a GVN54 garmin GPS and protocols to make it do what ever and work on what ever I want it to.
those that had the GVN53 setup that I did years ago - think that idea but integrated into the OEM controls.
years ago I mapped the associated buttons on both the early and later cars. I know where things are on the system and with some dicking around I can put those buttons and the joystick to use.
question for you lot - are you interested and at what cost?
DISCLAIMER:
THIS DOES NOT FIX THE LANGUAGE ISSUE AND I DO NOT OFFER THIS SERVICE.
Not doing V36.. Car is too different to the USDM car. If someone can go without their car for a few weeks then I may consider it but very few of you are going to part with your cars for that amount of time let alone $2k+ for me to do my job.(most of you think I work for nix - I don't.)
At least with V35 I can mock the system up and break into it easily. V36 is not that easy unless its a NON NAV car. Then I have that one done completely. Touch screen and all.
A note to the guys in melb looking at V36s and then wasting 30 minutes of my day dreaming about your next car... The info is here. If you read it THERE WILL BE NO NEED TO CALL ME! You know who you are- stop calling looking for English conversions that do not exist.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
