parting out my r32 4 door as i have decided to build a s13 as the 4 door body is to bent.
selling everything off it minus motor, gearbox wiring hubs and rear diff. wheels are not for sale
both guards, tail lights, indicators, headlights, front bar and reo, rear bar, glove box, plastic trim that goes around gear stick, dash vents, front seatbelts and c pillar panels are all sold.
Bonnet has one or 2 small dents and clear coat starting to peel in one spot. $60
Front doors pretty gc, $150 each minus door cards
rear doors both have dents. $50 each minus door cards
rear reo bar gc. $50
dash has some bubbling $60
boot lid has scratches and dents $30
rear seats would be pretty good with a clean $30
passenger seat gc $60
LF door card in good condition no switch. $50
RF door card not so good missing abit of material around handle $30
rear door cards in gc $40 each or 70 for both
centre console gc $40
dash has a bit of bubble on left side $50
only got drivers a pillar panel has 2 tears in it $15
drivers master window switch, everything works good except LF switch is sloppy and will only wind window down $50
Straight through 3" cat back exhaust with cannon i think 4" outlet has been dragged on ground a few times $140
shell will be for sale once it is completely stipped unless i get a good enough offer now.
Prices are negotiable, heaps more parts let me know what your after.
can msg more pics if wanted
0434950923
Located on the sunshine coast qld 4556
https://www.sau.com.au/forums/topic/429687-wrecking-4-door-r32/
Hey,
Ill take the rear door cards (both) posted to 7315, Tasmania. Will pay for postage of course.
Also im after:
1-DASH STEREO SURROUND: example; http://www.ebay.com.au/itm/JDM-Nissan-Skyline-R32-Stereo-Gear-Surround-/330913215143?pt=AU_Car_Parts_Accessories&hash=item4d0bf6f2a7&_uhb=1
2-Bonnet Latch and Cable
3-Front parking/indicator lights (pair) without cracks/chips. example: http://www.ebay.com.au/itm/NISSAN-SKYLINE-R32-GTR-GTS-SMOKED-CLEAR-CORNER-LIGHTS-INDICATORS-RB26-RB20-nismo-/221197912270?pt=AU_Car_Parts_Accessories&hash=item33806c48ce&_uhb=1
Edited by waterbirth
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
