Really? That's one of the best thought out responses you are likely to get.
yeah man, I tend to have this thing where I kind of understand but don't, so need someone telling me a solid yes or no.
but other than that, got complete rb25det ready to be mashed up with the rb30 :P
What I meant was using an RB25 Neo turbo head and it's inlet manifold .
It's not an easy job grafting a RB26 inlet system onto any RB25 head and if driving conservatively much of the time I don't know why you'd bother . To me there is only two reasons anyone would ever go with an RB26 head and they are the shim under bucket lash system and the six throttle inlet manifold . The aims being valve train reliability at very high revs and sharp throttle response . Big revs is not a consideration for normal road driving and single throttle inlet systems work fine in these applications .
So basically yes I think an RB30DET based on the Neo turbo head would be easier to get better consumption from - particularly if you can get the static CR around 9.5 to 1 and run it on something better tan basic E10 or 91ULP fuel .
I'd also consider using a taller diff ratio like say 3.7 or 3.9 because doing close to 3000 revs at 110 km/h won't help consumption . A 20% larger engine can in theory pull 20% taller gearing which works out to be around a 3.29 diff ratio , not hard to see how that's a bit extreme so if you halved that to 10% it works out to be a 3.7 final drive ratio . Lighter VL Commodores with RB30Es (SOHC 9.5 CR) from memory had a 3.45 ratio final drive and something very similar to an RB20DET gearbox inc ratios .
A .
Edited by discopotato03
A .
thanks mate. my goal is to just gain more rwkw and better response in comparison to my NA RB25DE Neo without compromising fuel economy . no need for high revs as I've never gone over 5k rpm anyway.
A .
your memory must be failing you :-) rb30e sohc had 9:0 to 1 cr , not 9:5 to 1 due to cats piss 88 octane available at the time Edited by StevenCJR31
Yes well memory fades and yes we did start out with urea grade ULP .
Anyway torque is king IMO and getting it in a reasonably free spinning package can only be good . I hear people say that in basic terms the difference between an RB25 and an RB30 with the same lid/CR is about 500 revs . I think at the end of the day the head and manifolds have a large say in the total power potential and the capacity dictates at what engine speed you reach the top ends limits .
Obviously more cubes means more torque at the same revs or same torque at ~ 20% less revs than a 25 .
If you soft pedal most places with small throttle openings and lowish revs then the 30 is good because it will pull higher gears down there more easily than a 25 .
If you give it taller gearing , final drive , you will get a bit more speed in the gears and make the best of the extra low down torque . Life would be good cruising down the Hume at 110 doing 2500 revs and never having to change down . If you sized your turbo so its not trying to boost at these revs every time you touch the loud pedal and tune the engine properly it should get good consumption .
A .
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
