i read up on em ages ago (bout 2 years ago) and it was something along the lines of no diffusers present in front of globes or something. have to check it again to make sure it still applies.
yeah i guess, I just don't like the way its so chunky between the globes, like its not smooth at all, its like 2 steps... more hacked together than anything else, not really there for style points.
trust me holdin it in your hands it looks good for all of 5 mins then you go... eugh.
a simple mod like opening up your headlights and just painting the reflector black (not the ones in the globes obviously) makes a world of difference.
like this... cost $5 for black acrylic paint.
Are there pics of these bad boys fitted to a car? How do you open the headlights?
Mate have you got any pictures of the headlights you painted on the car?
Looks neat.
have you got any pics of this where you can see the whole front of the car?
I like that man, is it hard to opening up the headlights?
not hard at all... exact same process as opening up your indicators, see my DIY guide on this thread.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=42193
Same process. if you guys want I'll make a step by step guide for that as well.
YESSSS WE WANT A PIC OF IT FITTED!!! hahahahaha
haven't fitted it yet lol coz I've only done one, and then I destroyed it to make my prototype with added fibreglass and the High beam relocated... etc... it looks like a mangled mess now.
