Gents & Ladies.
12.30 p.m. to 5pm drive day at the creek. $100 if we get 15 people and we should, $120 for less. Full face helmet long sleeve tops and bottoms. Spectators OK, passengers OK, no cost.
Any more questions please post for an answer.
Be there or do the speed limit.
https://www.sau.com.au/forums/topic/43-eastern-creek-drive-day-16th-may/
  • Replies 112
I have a small list of things to do to my car before it goes on the track, if I can get these done then i will be there, otherwise i will be spectating only.
The List;
[list:3014123954]
[*:3014123954]Fuel Cut Defender
[*:3014123954]wound up to 12 or 13 psi
[*:3014123954]speed cut removed
[*:3014123954]cold air induction fixed up
[*:3014123954]4pt harness put in
[/list:u:3014123954]
Then i'll be there!! :D
He's got a point, comon Prank ..... I mean, what are all those mods anyway without a pit crew wearing schmick overalls with your name and sponsors badges plastered all over them ....
or maybe .... your jusst .... CHIKEN :wink: burrrkkk .. brrrkk brrkkk.. /end poor chiken impersonation.
Well,
Its looking good, 20 + people so far.
1. Oz GTR
2. Zane GTS
3. Peter CRX Honda
4. GTR-51K GTR
5. Dflash GTS
6. Silver Arrow GTR
7. + Friend
8. + Friend
9. Bonks GTS
10. Dazsta WRX
11. + Friend
12. Zoran GTR R34
13. Simon GTI Pulsar
14. Roy GTS
15. +Friend S14
16. +Friend Merc
17. Red900SS GTS
18. + Friend RX7
19. Duncan GTS
20. Jimbo GTS
21. Prank GTS
22. Greg 911
23. Shane XR8 Ute
24. Evan VR V8 Ute
25. Gts32t GTS
26. John WRX
27. Akira GTS
28. Fats GTS
29. Majanal GTS 50% atm
30. PH GTR 50% atm
Guest gts32t
Ello gents new to this forum, so ello ello everybody. I am very keen on this event, is the price any cheaper the more cars that attend? I will be bring a R32 GTS-t - very special specs, just like Prank I have a hell of alot of bolt on bit in the garage that need to go on before the track day but this should not be a problem, and I should be ready.
GTS 32t,
We already have a discount rate of $100, the usual price is $135 per car or $125 for 3+ or my deal which is $100 for 15 or more. At the moment we have well over 20 people so as long as everyone turns up we will be driving at $100, but bring $125 incase 50% of the people pull out at the last minute.
Guest gts32t
GTS 32t,
We already have a discount rate of $100, the usual price is $135 per car or $125 for 3+ or my deal which is $100 for 15 or more. At the moment we have well over 20 people so as long as everyone turns up we will be driving at $100, but bring $125 incase 50% of the people pull out at the last minute.[/quote:8ce458ef55]
When do I have to give my final notice that I will be coming.
GTS 32T
As it stands you are down as coming, just let me know if you can't make it .
With the numbers we are getting it looks like we will have 2 skyline groups, fast and slow. Finally what looks to be a great turnout, bring it on.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
