Hi all,
I have an White r33 gtr for sale, 112,xxx klm on the clock.
When I got the car the bottom end was stuffed so I am in the process of building another engine for it.
Another bottom end has been used with a fresh rebuild, (rings, bearings, hone, new seals, reshimed head, gates timming belt).
The car has r33 gtr wheels on it with new tyres (245/45). Coil overs, boost guage, and 3.5" exhaust with tuned y-pipe and split dumps.
Stock turbos that have been port matched with the manifolds,
car also has an aftermarket front bar, (not sure what brand), and H1 HID lights (low Beam).
The engine is still being put together at the moment and will be run in before sale.
If any one is interested in the car and would like to see the engine before its is complete you can contact me and we can arrange something,
im asking $20,999 ono with rego and road worthy.
Located in Brisbane.
Thanks
https://www.sau.com.au/forums/topic/430065-r33-gtr-1995-white/
Some more details
Acl race series bearings used on both big end and mains.
Oil restrictor in block.
Standard oil pump
Standard water pump
Standard Rb26 Pistons and Rods, with Genuine Nissan rings.
New gaskets and seals.
All valve stem seals replaced.
Valves reseated into head.
Head decked.
Block honed
Standard head gasket.
Gates timing belt.
Stock injectors and computer.
Hks Tuned length y-pipe
Split dumps,
3.5 to 4" exhaust
Tanabe Coil overs, fully adjustable.
Pivot boost gauge
Excellent condition interior.
Brembo brakes.
Pics are on there way...
  • 1 month later...
Hi all, bit of an update.
Car is running and will be registered this week then off to the dyno for a run in.
still waiting on a few parts to finish it of but I am still open to people coming to have a look if they are interested.
Hi all,
More pics are coming soon, waiting on a new front grill, and a polish.
I will be open to offers including cars for trade.
I would be open to 4 door 4 cylinder cars preferably turbo. (eg, WRX, Evo, GTIR, VW GTR, Liberty or A4 Audi.)
I will def consider others also.
thanks
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
Hi all its been a while.
Price drop to $19 900. to any one interested I will look at offers also.
Just had a rear wheel bearing replaced also.
Edited by Muff
Hey mate was just wondering if you were considering swaps?
2005 bf xr6 turbo. Has 320rwkw, 6 speed sports shift auto, clean, has almost 160000km comes with spool rods, cp pistons, arp studs, big actuator. Has a full exhaust, valve springs, injectors, fuel pump, oil feed line, zip kit in gearbox for firmer shifts, DVD player installed but haven't made the appointment for it to be wired up yet, gauges on dash, plazman 800 cooler, hot side cold side pipping, currently running on 13psi. If motor is built (parts supplied) it will handle 1000hp claimed by spool. Vic rego until November.
  • 3 weeks later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
