I’m regretfully selling my pride and joy due to work commitments overseas so I need to sell it as I will be moving soon. Specs as below, may have missed some parts I have on the car so yeah.
Asking a reasonable $13800ono
Located Sunshine Coast/Brisbane
ill sell NOT20 personalized plates with the car if offered a good price!
Please msg on 0402548298, dont always have access to the internet if u pm me :)
ENGINE
Car made 350hp @ the wheels on 11psi, will easily crack 400hp with more boost
RB25DET motor and box conversion (mod plated and all)
Cams
Forged Internals
Short shifter
Redline mt90 oil in box
Always used penrite 15w 40 oil, serviced approx every 3000Km if not less
Garret T3 high mount turbo (not sure specific model)
Haltech ECU tuned by matt spry
ORC twin plate clutch - rebuilt about 2000km ago by direct clutch. Its pressure rating is just under a track clutch, so it’s real heavy.
Oil catch can
Spal 16” thermo fan
10 Row oil cooler and oil filter relocation kit
Fuel regulator
Walbro GSS341 fuel pump
Big front mount Intercooler
SUSPENSION n BODY
Front and rear adjustable camber arms (fronts haven’t been fitted yet)
Front and rear adjustable toe arms
Cusco 2-way
Front and rear strut brace (cusco)
Front whiteline sway bar (not fitted)
Rear tension bar (located in boot)
Coilovers - front cusco, rear authentic tein super street coils
Wheels and tyres (federal 595 evo all round on 350z rims)
Front Wheels: 17x7.5 Inch +30 Offset (Rubbers just about brand new)
Rear Wheels: 17x8 +33 Offset (Rubbers are close to new, light camber wear on the inner but practically new also)
GTR Bonnet
GTR Boot
Bolt on rear guards
Boot spoiler
INTERIOR AND ELECTRONICS
That fresh R32 skyline smell
GTR front seats
Autogauge smoked gauges (Oil temp, Water temp, Boost) mounted under headunit
Alpine stereo
Climate control - Air con works just needs to be regassed
Apexi RPM/Speed meter
Electronic line lock switch
3 1/2” exhaust with varex silencer
MUCH MUCH MORE.
The motor and box came out of an imported r33 which (on the auction report) had forged internals and bigger cams. This I cannot prove as no receipts for motor build were supplied.
post-76888-0-42913400-1376353949_thumb.jpgpost-76888-0-74532200-1376353988_thumb.jpgpost-76888-0-63161400-1376354073_thumb.jpgpost-76888-0-50375200-1376354115_thumb.jpgpost-76888-0-41087000-1376356750_thumb.jpgpost-76888-0-09220100-1376356817_thumb.jpgpost-76888-0-66763900-1376356862_thumb.jpg
Edited by mafia
  • 1 month later...
Guest
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
