Measures 2000mm between the guards, take up to a 2850mm wheelbase, 1450kg car. Smooth riding full shackle rocker suspension, registered, five new Sunrasia wheels and tyres, over ride disc brakes, protected LED lights, dual ratio winch, etch primed Algal chassis. Built by a pro as a keeper and way better than an Ebay cheapie, now $1000 under factory price, sell for $4215. Phone Richard 33543204 or email [email protected]
  • 3 weeks later...
Trailer wheels and tyres cop a hiding, this trailer has new Sunrasia wheels which have heavier rims than old car wheels plus it has new light truck tyres including the spare.
  • 3 weeks later...
  • 2 months later...
  • 1 month later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
