Sau Nsw Official Half Way Robertson Meet Up 15/9/13
Ah that sucks. Well I just finished my ten day stint and have the rest of the week off :P
Not that that makes you feel any better :(
Pretty keen for this :D
Shell signed blood so she coming.
Bad luck Chris ! I would rather next week off ! Because GTA IS COMING !
Eh.. Only games I play these days are racing games/simulators. Have built myself a pretty epic setup/cockpit :P
BF4? :D!
Haha still unsure.... I was a massive fan on bf2 10 years ago, over 1500 hours played back in the day lol. Bought bf3 and played it for about 2 months then was over it. I have a feeling bf4 will be a repeat of bf3 so I'm a little hesitant :(
Whereas I get a solid 4 hours a week out of Live for Speed, and don't get bored with that :D
Edited by dontyellpl0x
EA admitted to breaking BF3 - BF3 SUCKED ! however, they've realised their faults and will be fixing everything in BF4. By a start - they brought back commander
BF3 was amazing. The early maps where nothing special but the actual game was the best FPS released to date. The newer expansions are amazing.
New generation BF player? Becuase BF3 was probably the worse Battlefield installment. The graphics are amazing and to date, the best still. But the gameplay, competitive mode (There is no competitve mode - so you can't play BF3 competitively) and no commander, wayyy to many OP things example Anti-air and Jets do like 50% more damage to Helicopters - mind you Helicopters are a still target yet can be shot down in a second). there were MANY of things broken with BF3. Yes it was a good game from BF2 - but they quickly killed the game. Also, BF3 is dead - there are a total of like 10+ servers active during peak times.
I wouldn't complain anything is OP in BF3 tbh. Everything can be countered. ive got full platinum stars for both jets and choppers and i can get in one and make it last the entire game. Honestly the only "BROKEN" thing was metro with nades and rockets. Brilliant game.
Bf4 will be amazing. Not quite as good as GTA 5.
BF3 is dead and has been dead for quite awhile. I am a HUGE Battlefield fan and have been playing since game 1. EA have already admitted to its mistakes (Hence BF3 sucking) but they've promised to deliver in BF4 to which I think will happen.
Anyways, got that phonecall yet?
Edited by RosieR34
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
