Morning all
I feel so dumb asking this question as i did 4 years working with these things but is the Trust T78/T88 manifold actually a twin scroll manifold?
We are upgrading the T78 turbo to a Precision Turbo 6766 and want to make sure i get the right housing
The manifold and turbo appears to be split pulse/twin scroll as it is divided, but i had this idea in my head that it needed to have separated, twin wastegates to be a twin scroll manifold
Help would be greatly appreciated as i am about to put a deposit on the new turbo any day now
Thanks in advance
Brad
Does not have to have twin gates to be a twin scroll. Just needs the single gate located in the right position. At work can't full explain.
All the t78/88 manifolds I've seen are twin scrolls.
Josh
Thanks Josh
I have neevr actually looked at, or thought about, twin versus single scroll turbo's and now that we are going to swap the T78 for a 6766 its something that has been asked
I nitially just said an open turbo, but glad i looked as i would have made quite a costly mistake
If you have a TS manifold and can get a suitable TS turbine housing then you should have gains low down.
At the top end the divider might cost you a little.
I would go for the TS housing since you have a suitable manifold and enjoy the better response.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
