Surely you don't have that much free play to suspect bushes. I have a sound which is just like yours a sequence of ting ting tings. Its my exhaust hitting my tailshaft when going over bumps or fast around turns. I can't see the bushings causing these kinds of noise especially if you don't have other symptoms. Get under there check the bushings out, you should be able to see such damage. Also check the clearances between your exhaust and the body/tailshaft. Also another common cause, depending on your exhaust, it could be the exhaust bumping on the diff housing. My old HKS did this, I glued a chunk of rubber to the exhaust in the exact point of contact. Shaking your exhaust generally wont recreate it, its kind of a trial and error diagnosis.
You could just take your car to a suspension shop get them to inspect the whole subframe and bushes see if they have excess play or are cracked etc.
https://www.sau.com.au/forums/topic/430353-noise/#findComment-6973864
As per above
- Get underneath and have a good look. Give it all a good shake.
- If you can't identify then take it into a shop and get them to check it out for you - Get a diagnosis and cost to fix.
- Ask them to show you so you know your not being ripped a new one. (some shops will !)
- Decide to pay or DIY.
https://www.sau.com.au/forums/topic/430353-noise/#findComment-6973929
Pedders lol. They're dodgy as f**k. You walk in there, you will almost ALWAYS walk out with a bill. They quoted me $1300 for some shit on my old car and the exact same number on my current car which has been fine for 2 years since they've checked it. Funny enough all the stuff they pick on is pretty cheap parts wise but always labour intensive, so you know they're making the most money out of you. Its not like paying 1k for suspension set plus install where they make a hundred out of you, this is about 300 in parts and 1k in labour.
https://www.sau.com.au/forums/topic/430353-noise/#findComment-6974150
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
