Just pulled these of my rb26. Perfect condition, as new shaft play. Awesome power capability.
Located in bayswater Vic.
Would prefer pick up, but could arrange postage at additional cost (buyer responsible for any shipping damage).
$1500 for the pair.
Can post or email pics if required
https://www.sau.com.au/forums/topic/430551-vic-pair-of-2650-5-turbos/
They're were on the car when I bought it but based on condition and previous owners reports they're less than 2 years old and seen less than 2000kms. Your welcome to inspect yourself or happy to arrange a professional inspection.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
