  • Replies 275
Modified skyline insurance???
Whats that??? Lol
I saw you at WTAC but by the time i came to say hi you were goooone :(
So a belated HI :action-smiley-069:
Looking for cheap hotels in Mildura and Wagga Wagga now.
I can recommend this joint: http://mildura-deakin-holiday-park.vic.big4.com.au/
I stayed the night on the way back from adelaide to orange, I parked the car+trailer beside the cabin. It's on the main road, secure and there's a bakery next door for morning munchies before going again.
Response from Mawson Lakes Hotel about parking on site is: "We have you booked into a connecting 3 bedroom apartment located 100m from the hotel there is secure parking there and secure parking at the hotel with CCTV footage."
OK, booked accommodation in Mildura for the night of the 20th. 3 bedroom was gone but I have booked a 2 bedroom cabin with bedding for all beds. Cost was $160 for the night. They will leave the key and a map out for us in case we turn up late and also said there wouldn't be an issue with parking.
Edited by DekA
In Wagga Wagga on the way back there is the trailer park option:
Ensuite cabin has one bedroom with bunks in the passage way for $164 for the night:
http://easts-riverview-holiday-park.nsw.big4.com.au/accommodation-and-pricing/cabins/15859/ensuite-cabin.aspx
2 Br w/loft bunk cabin has queen bed in master bedroom and double bed with single bunk in second bedroom for $230:
http://easts-riverview-holiday-park.nsw.big4.com.au/accommodation-and-pricing/cabins/17844/2-br-w/loft-bunk.aspx
Also liking the look of The Boulevarde Motel. Delux Twin is $165 and Delux Double is $125 and the hotle features "Off street parking with camera surveillance". http://www.boulevarde.net.au
#@75coupe - Happy to share a twin room?
#@luke gtr - Assume you and Kate would want to book your own room?
kates not coming, im flying solo.
In that case, cabin it is!
I've booked the ensuite cabin at the caravn park in Wagga Wagga which comes to $149 for the night. They said there will be parking for all of us and if we turn up late they'll leave a key and a map out for us.
So all accommodation is now booked and I can relax :)
I've paid for the two overnight stops which you guys can fix me up for when we meet up.
Lazy buggers..
Accommodation costs are:
Mildura - $160
Wagga Wagga - $149
Adelaide - $250 per night times 4 nights - $1000
Total of $1309
Which makes it $436 each
I've paid for the nights in Mildura and Wagga Wagga already, we pay on checkout at Mawson Lakes.
Lazy buggers..
Mildura - $160
Wagga Wagga - $149
Total of $1309
taken colour code away to see on black theme
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
