  • 5 months later...
there is no ipod mode in the stock V35, need an audio cable of some sort installed. had one done by audio express and it used to control the ipod when in AUX mode, also charge the ipod etc. and can control the ipod with the steering controls also.
  • 1 month later...
Hey guys, just picked up a V35 coupe and looking for a simple iPhone connection to play music.
What I've found from searching is that I can buy a cable that connects into the tv tuner in the boot with RCA's on the other end.
Can I then get an RCA cable with an iPhone plug on the other end that will play and charge the iPhone through AUX on the Navi?
Chris Rogers, you appear to be the expert on this. Have you developed a better method? I want to keep all the stock audio gear in tack, just looking for a good way to play music from my iPhone.
Thanks.
How was this achieved exactly?
Also looking for the best bandwidth expander available for the V35 stereo to receive sydney radio stations...
Probably capable of installing this stuff myself, but if someone has found a good guy here in Sydney I'd be happy to let them sort it.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
