Hey, i've noticed that my rear wing and roof has these grey/white spots all over it, i've been watching it for a while and it seems like its like fungi or someshit cause it grows.
I've rubbed my finger over them and its smooth, its like its under the paint. Been polishing my car every month
Been taking good care of my paintwork since i bought the car but these spots just came out of nowhere lol and they keep getting bigger
my car has the paint code kr4 which is silver
any ideas?
will post pics when i get home from work
https://www.sau.com.au/forums/topic/430874-chalking-spots/
any ideas?
Do you use a car cover?
https://www.sau.com.au/forums/topic/430874-chalking-spots/#findComment-6989108
its smooth like the rest of the paint, no known chemicals have been dropped on the car, it started on the wing, then i noticed it on the roof the other day, its spread evenly across the roof and wing only, its wierd lol
https://www.sau.com.au/forums/topic/430874-chalking-spots/#findComment-6996166
weird as. if its smooth, can probably be buffed out. but, it could also be clear lifting and ready to peel. kinda hard to say without seeing it in person
take it past a deecnt panel shop and get a pro's opinion maybe? im kinda stumped
https://www.sau.com.au/forums/topic/430874-chalking-spots/#findComment-6996173
yeh im kinda leaning towards that the paint is fading under the clear coat :/ dont think its repairable unless i get it resprayed which i dont have the cash for because i just spent $8500 on rebuilding rhe engine haha damn
https://www.sau.com.au/forums/topic/430874-chalking-spots/#findComment-6996182
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
