Mugabetown - Whoretownin' At It's Worst.
My brothers mate actually did fark a pre op tranny on the ass in Amsterdam...didn't fond out till he flipped him over and saw the cawk. Unlucky for him it was in a hostel dorm with all his mates to witness.
He will never live that down, It belongs on his tombstone.
muah ha ha ha hah........poor bastard. Traumatized for life
I never let him forget it either, poor bastard. Ruined the rest of his Europe holiday.
This is the response to every argument you ever have with him ever...Hey guy the sky is green.....Not it isn't.....You screwed a tranny....
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
