Mugabetown - Whoretownin' At It's Worst.
Nah ga16
We have 1 or 2 SSS come in. One is bone stock and the other puts out about 190kw atw
Yeah, someone was selling a 240kw awd import bluebird for $5000 a few months back on Antrax unfortunately didn't have money and was in SA.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
