Mugabetown - Whoretownin' At It's Worst.
I can imagine.
Yeah... Will hopefully find out more shortly and release our planned course of action early next week. With everything happening, not a situation that I really want to put the club in, but we shall see....
am i not a real whore?
I am internally debating this given your previous proximity to whore houses during "work hours" perhaps your more whore than all of us combined...
Tony, Is this something that will impact on the member base or something that is impacting you personally? Either way we are here to support you but this vauge shit does my head in. We are all grown adults here so shit or get off the pot.
Ok, here it is as it stands.
Scott has stepped down as VP and this sucks. This sucks because it means that there isn't someone there that I can argue with about shit and he was probably the best that the club will find for the role. Due to the legislation in the by-laws, this needs to be filled. After the shit f**king week/ month/ quarter that I've had, it's not something that I want to deal with - yet. Losing McFly was a very tough blow and honestly, I took it personally. Losing Scott as well makes things even more difficult as both of sweated and bled to bring things to where the are. I was holding off till I spoke to him this arvo, and also wanted to speak with a few other forces of influence before announcing anything but here we are.
This sucks the fat one, Thanks for telling us.
You have our full support and while no one will ever be able to fill Scott's shoes and do things the way he does someone from amoung the member base will be able to fill the role and grow into it with the support of the Club and the Past / Present Exec teams.
Ok. So what are the procedures from here?
There is a placement open for VP role lets fill it up.
Do what you need to do to find appropriate candidates for the position (easier said than done I know), then is it a matter of nominating that candidate into that role or is this carried out by the executive members??
Either way, you also have my support. Don't forget this is a club and if people truly care about it they will do something to help you.
Vote 1 Ants for VP
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
