Mugabetown - Whoretownin' At It's Worst.
Pub in the home...gah!
Tap king makes this possible, I am taking lots of on call work at the moment though, this also cuts into beer time
My car will be done before yours at this rate!
Just jinxed your self!
don't believe in that crap! Everything happens for a reason. Whether that reason is fair or not is another story.
I'm starting to find out that if you let things slide nothing gets done.
It appears that you have to fight for what you want theses days.
As for Tap King, gimmicky idea that has been well marketed this time around. Didn't work so well when they tried it with Heineken a few years back.
If you want REAL tap beer in your home you should go talk to these guys http://www.brewsbrothers.com.au/
When I had more time on my hands (and a housemate who loved to drink as much as I did) we did bottled beer with them. $150-$180 for roughly 6 1/2 to 7 cases of whatever style of beer you wanted.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
