Mugabetown - Whoretownin' At It's Worst.
I wouldn't worry too much Ants then, the other gaskets will.most likely arrive by then anyway. Thanks for the offer though. I've put off getting anew cat for over 6mths now another week shouldn't kill me. Kinda wondering wether theres gonna be a volume level differencd has currently farked stock one in it.
From my experience there is no difference in sound
I still don't understand how something with holes in it stops anyrhing
What do you mean?
The cat is there to heat up and catalyse un burned hydrocarbons,carbon monoxide and nitrogen oxides into more friendly substances
What do you mean?
Surprisingly that came out really.well and I understood all of that.
ok go! are a band, so i wouldnt suggest you get them to fabricate an external fuel system for you.
if they can fab anywhere near as good as they can use treadmills, then I'll use them!!!!
RandomHero / Pannel Gaps / TheB@man is no longer affiliated with the Skylines Australia website, Members may contact me via the usual methods but i have no further intentions of utilising this page and thus encouraging and supporting a site that is Administered by Egotistical people. Thanks for all the whoring fell's an gal's but I'm done here.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
