Mugabetown - Whoretownin' At It's Worst.
Any indication of when? What did he say about the FPR pressure?
Indication early next week
They pulled the fuel pump out and identified a small kink in the line
I told them about the FPR and Ben (I think I was speaking with a Ben :dry: def not Sean as he was on the Dyno) put a fuel gauge on the car and he said its reading 300kpa so thats a good sign (approx 43psi)
Still need to do a few more poawa runs and hopefully its done.
Awww thats kinda sucks
Never had such a hard time b4 with mechs and tuners - everything appears to be lob sided theses days :/
well thats good.
The EFI thing is unfortunate, he would have had a tight schedule leading up to powercruise then when yours required extra work there just would not have been time to do so with out fecking everyone elses schedules to hell.
I actually feel kinda bad about recommending you go there now, but I still maintain the tuning work will be worth the wait! Sorry! :(
Not your fault mate.
I am sure Sean does good things. Which is why he is so busy too.
Bad timing appears to be my detriment.
Nothing I can do there but try to play my cards right.
A smart man told me once 'that good things take time' he knows who he is :turned:
Hopefully x all fingers and everything else the Ant-eater will be done and I will be driving it :worship:
I remember going to EFI/ERD last year just before powercruise. Let's just say insanity was an understatement. They were BURIED under work.
yep its really full on, same thing before Jambo
I've been forever pondering lately what gets prioritised through workshops / tuners
seems like FIFO is not something you can rely on as turnaround indicator
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
