Mugabetown - Whoretownin' At It's Worst.
Any indication of when? What did he say about the FPR pressure?
Indication early next week
They pulled the fuel pump out and identified a small kink in the line
I told them about the FPR and Ben (I think I was speaking with a Ben :dry: def not Sean as he was on the Dyno) put a fuel gauge on the car and he said its reading 300kpa so thats a good sign (approx 43psi)
Still need to do a few more poawa runs and hopefully its done.
Awww thats kinda sucks
Never had such a hard time b4 with mechs and tuners - everything appears to be lob sided theses days :/
well thats good.
The EFI thing is unfortunate, he would have had a tight schedule leading up to powercruise then when yours required extra work there just would not have been time to do so with out fecking everyone elses schedules to hell.
I actually feel kinda bad about recommending you go there now, but I still maintain the tuning work will be worth the wait! Sorry! :(
Not your fault mate.
I am sure Sean does good things. Which is why he is so busy too.
Bad timing appears to be my detriment.
Nothing I can do there but try to play my cards right.
A smart man told me once 'that good things take time' he knows who he is :turned:
Hopefully x all fingers and everything else the Ant-eater will be done and I will be driving it :worship:
I remember going to EFI/ERD last year just before powercruise. Let's just say insanity was an understatement. They were BURIED under work.
yep its really full on, same thing before Jambo
I've been forever pondering lately what gets prioritised through workshops / tuners
seems like FIFO is not something you can rely on as turnaround indicator
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
