Mugabetown - Whoretownin' At It's Worst.
I've been forever pondering lately what gets prioritised through workshops / tuners
seems like FIFO is not something you can rely on as turnaround indicator
I think FIFO is the goal, but in your instance it was something that required extra work they didn't account for so inorder to get more cars out faster yours sadly went on the back burner :(
Whatever order makes them the most money the fastest?
here are my thoughts
regular service work = consistent cash flow = priority no.1
sponsoring work = zero immediate cash flow but free advertising = potential future cash-flow = priority no.2 (my mind is still debating this)
project work = infrequent cash flow = priority low
all the above depends on size and demographics i.e. manpower of the workshop(s) but as a general rule of thumb I don't think I'm too far off the mark.
Also for non service work i.e. large repair jobs or builds - if a workshop tells you it will cost you this much $xxx - budget for $xxx * 2 as there will always be additional costs they fail to mention (unless you know someone who will do it at a discount or lower chargeable rate)
Or get Dan to build your engine...
I'd say sponsored work goes to the back unless it will have immediate impact on future business, e.g. a sponsored car shits a bearing right before major event. This is bad as visibility is important so it'd go up the queue, otherwise it'd be dead last IMO
would really depend on the type of sponsor being provided to really answer that question
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
