Mugabetown - Whoretownin' At It's Worst.
the c63 beat noels 33? his car is making more power than the C63 though and weighs a lot less.
The c63 had an exhaust and a tune. Was making similar power and the auto was very good at putting the power down. Also no lag
poor bunts with no car, i have 3 and you can borrow one if ever you need. ps. i also have jumper cables and a jump pack that can get you started many times if ever you want to drive the unicorn. oh and a charger that does trickle or "maintain" for when you are parking up for a long time.
When I get the new battery I will also be getting a trickle charger for sure
My new solar trickle system is great! I've been driving a bit more often this month and the battery holds charge beautifully as opposed to before where after 5 days of inaction it was not liking turning over and after 2 weeks it was f**ked
    • I have been wondering if this is as simple as a voltage issue with the battery. Even on a charger, I can’t seem to get it over 11.8V on the terminals.    Unless the alternator has failed as well, that wouldn’t cause it to die in the middle of driving though.
    • I’ll give this a shot next time I’m able to wrench on it.    I was able to get my hands on a Haltech Nexus, so that should help with some of the more bizarre troubleshooting. Make sure the CAS is actually sending signal and will be able to set the proper dwell on the R35 coils.    I’ve checked power/grounds/signals at the CAS, ignitor, and plugs and it was all there. Granted this was static with ignition on, not cranking.    I also plan on swapping out the fuel filter and throwing on a fuel pressure gauge at the rail just to confirm I’m getting the correct pressure at the rail. 43psi if I recall correctly.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
