Mugabetown - Whoretownin' At It's Worst.
tony, the drugs.. lay off them..
anyway whats going on tonight to make you sound like nick?
nick left us for the new whoretown, loser.
Shit at work
Arguments at home
All for what seems to be nothing. Not a happy camper. Scotch helps
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
