Mugabetown - Whoretownin' At It's Worst.
If a crank trigger could work easily with the stock ECU or PowerFC I would defiantly be blowing up the CAS
Yep they appear to cause their fair share of headaches.
After Bunta (Andy) explained to me the inherent issues associated with them - having a crank trigger setup is almost just logical really.
So nearly killed my engine today
Had danger to manifold on the HUD and warning sounds and sirens and lights and I looked like this
Posted Image
But seriously nearly killed it
What did you do to it?
Silicone hoses yesterday. And boost tee. grandad took my radiator cap off didnt out it back on all the way
Went to supercheapauto this arv drive it like a granny so no boost whole way
Put tee on.
Driving home pulling over and adjusting
Got in.... Drove... Looked down..... Temp was all the way up
Pulled over waited like 30 topped it up and grannied it as fast as I could all the way home
It's in driveway cooling as we speak so I can too it up then go tell my grandad he owes me a vr38
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
