Mugabetown - Whoretownin' At It's Worst.
None of you mofos know howto answer a f**king question lol. Cowdy. If you have exceeded the air flow limit of the ecu by say.....upping boost you will get the symptoms you describe. It could also be an air leak from when you installed the new hoses. This advice is based on the problem occuring only after making your recent changes.
Who said that we were useful?
Or the symptoms are the same as failing coil packs after upping the boost.
Mikey was closest
Igniter gets up to a certain point and then just arks out like a mo fo, only under load tho. Boost back to stock and still doing it at 3000 so I sprayed it in silicone spray. Cut out a rubber may to sit underneath it. No more arking no more silly biz works right till the limiter
Did the same to the one arking pack first and it was still there
So new packs new igniter new fpr new damper and get it down before anything else
Question to myself. Why do I have heater, fuel, oil cooler, silicone and rubber vaccume lines, throttle body clean, silicone spray, clamps, fuel filter, tools and water in my boot. Oh yeah because when I got the car it was filled with useless sh*t that I pulled out and have a spares. Have needed some of it so I'm glad it's there
And wiring
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
    • Sequential Is fine to drive on the street
