Mugabetown - Whoretownin' At It's Worst.
Wow Tony, you went and made the QLD area all strict and boring and shit mate...
I was thinkign of hanging here more than the NSW section, but not any more...
I never made the QLD section strict. Said that everywhere else is.
We will always be the best part of SAU...because we have so little rules :P
Blood drive
Charity cruise
Happy laps
Sprints
Drags
Golf day
Etc.
We have those.
Plus tech nights
Plus lots of normal cruises.
Plus we have a better state... No banana benders here :P
