Mugabetown - Whoretownin' At It's Worst.
So you farmers whored today
What is this Kathryn whores more than me.....
Not anymore
Anyways Kathryn we let the people come and whore in here we don't mind
So I'm prettyyyy sure I'm looking into rebuilding my 190mm rc tourer
Clearly you don't know me very well. I am incredibly hard to replace and really am out of fcuks to give so if dropping my laptop on the floor and going fishing all I do then that would be really sedate for me.
Ha ha ha, you sound like you're in the same verdict as I am.
I got told the other day they won't give me any formal warnings, or sack me as they don't want me to go. Still won't give me a pay rise though.
They gave me a written warning one day then promoted (massive pay bump) me the next with a written apology for the written warning.
Bwahahahahaha! Epic work! I wish they'd just give me either my payrise I want, or the sack!
Bonus should be paid in a couple of weeks, waiting for it to come in to see how long I'm actually going to plan to stick around for.
Need moar conversation, Beer is tasty but company would be grand.
If I didn't have work tomorrow and had more fuel I'd come over and have a beer with you and keep you company XD
always welcome mate you know that. You need to watch Gankutsuou : the count of Monte Cristo it is freaking awesome very unique art style.
Unique style aye, that's a iffy one then I'm a little anal regarding anime drawing style.
Clint nothing much just looking at all the hobbies I used to have.... SHI* I USED TO BE A NERD
Trick is not to give up on hobbies ), I just slowly continue like my 40K hobby.
Seriously good art style.
I used to be a really good Magic player. I won a lot of games days and got into the top 50 in the country for it.
Tap king Teddy's are good shit. I had the chancer the other night, verdict is still out.
I heart chancer!
I too have 40k stuff. Have painted since I was about 10. Don't care much for the game itself. I thought your name must have been 40k related.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
