Mugabetown - Whoretownin' At It's Worst.
That's because IT workers are like assholes... I mean opinions... Everyone has one...
This is exactly why I work in a very specific area of IT, one that keeps the rest of it at arms length.
And most IT workers are assholes...egotistical assholes.
Yep, I'm an asshole, it's why I'm in IT... But not so much technical side, LOL
What do you do in IT specifically Clint?
I work in Control system security, I am responsible for the supply and support of the control systems, the Wan's and Lan's they operate on and the security of the off net network for a large utility.
So.... Zac and I got stalked today. And not by any random person. Zacs nan. She had a stake out. Just chilling in her car outside zacs work waiting for me to go see him. Wtf!! Messed up
lol Ninja Nana.
Sounds... Fun... :P
Get me a job with you? I feel the need... The need for acceleration (Change for those not getting the relationship) :P
Everyone works in IT now days the Industry is such a broad spectrum of jobs and people.
They specialise in particular areas but I don't need to/want to/not allowed to know what they actually do - All I know is they are extremely good at what they do and they have both being flown around to different countries for conferences, training etc... Good for me, I get souvenirs and they get frequent flyer points to fly me around Aus when needed yayyyy!
Sounds... Fun... :P
hahaha take a number and get in line, Heaps of people want in on what I do...There is a serious lineup to get into my field.
What IT experience do you have Matt?
None. Oh you said Matt not tony. :P
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
