Mugabetown - Whoretownin' At It's Worst.
Alledgedly everything is still running but the USB port slows down and Sean cant get any proper reading from it.
Haltech was sent back to Sydney yesterday (hopefully will get it soon) to have a look at it.
go in there man honestly. i dont know they guy but you know they havent touched it and now they claim ecu is dead. Id hate to find out they are jacking you man!
Hatlech said to Sean when he called them that this ECU has an older firmware on there and is apparently a known issue.
I asked Sean if Hatlech would replace it with a new one - hes said he doesnt know.
bottom line, is that I still have no car, and now no ECU im totally devestated with it all.
Never really thought of that Damo. I suppose workshops could pull BS like that and would not be suprised.
thats so low BTW.....
Back in the late 80s when the band was only first starting off buntas clean cut style dazzeled female onlooker to the point where photosynthesis was so popular fans start submitting their crowd shots (as seen below)
But by the early 90s the folk lifestyle had taken its toll on poor mr bunts and the band started to fall apart due to alcohol and drugs
After two stints in rehab and a rumoured romance with Michael Jackson, the band went into hiding secretly writing there controversial new album "Give me the keyboard to your heart... And your car" two years later the album was released to mixed reviews selling only 300,000 copies
I am not convinced that is the correct use of photosynthesis.
I don't think think using radiant energy to turn carbon dioxide and water into carbohydrate is the cause of your being boring. Though according to Ants you are green so maybe you do photosynthesise
I was a bit dubious on this use as well but Video ref has called play on...7 tackles later.
Less than half mate. $29 inc Cart hire for 18 holes. Practically giving it away
Is that for 1 or 2 people?
doesn't it still have a serial port as well? could of upped the baud rate on that in a pinch if it does.
  • Like 1
Go in there with a glitter cannon, that would make most people other than myself move quickly....
Unless they are like me and in which case they will be waiting in excitement for a shitload of sparkles to explode everywhere :)
(I changed my mind we can be friends)
Yippeee
My guess is that it is an excuse to buy them some time
Just no, Sean did not manage his workload well coming into two major events but he would not send an ECU back to Haltech to buy himself time.
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
