Mugabetown - Whoretownin' At It's Worst.
Was going to post something about Nick making excuses but he made one before I could :(
Not an excuse, cruise out my way and ill happily go for a run. Just don't feel like driving all that way, and not a huge fan of night runs
so..........................its all legit!
Just spoke to Haltech. They received the ECU yesterday.
Will not look at it till next week.
Dont expect to see the ant-eater in action for a long time :/
Boo that sucks Ant :( At least they have it tho... Which is kinda reassuring in a way...
I have no motivation left for today *yawn*
yeah it sure does sux dogs balls Mel.
But that at least its with them. Worst case scenario is that is fubared and will have to get a replacement one.
Only problem is I highly doubt its under any warranty period so the replacement one will most likely be forked out of my own pocket and any tuning that Sean has done will be gone (unless he can just reload any maps he saved which I think he would)
Mega suckiness right now.
Also feel demoativated
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
