Mugabetown - Whoretownin' At It's Worst.
Whats crackin????
Fantails, chippies, cake, coke, fanta, sugar high.... D fark... Been healthy eating to long, no longer grumpy, sugar ftw....
Oh haiiiiiii :action-smiley-069:
Just realised I won't get a chance to see the light show AND I MISS RIVERFIRE BECAUSE OF WORK :down:
Whats crackin????
Hi Melly, it seems to be a slow night on the forums
Note to self (well not really)... Pissed mid 40s women trying to get my attention... You're ugly as sin annnnnd this is why I hate the train :(
Sydney traffic atrocious forces you into the above.
What's Brisbane traffic like can you still drive in?
When I am on call I drive in, in peak hour its a 15 minute drive from my house, but some of the commustes around the place are pretty screwed up. Heading North is pretty shit as there is no highway.
It's not including parking or walking time, if you drive from Windsor to Sydney CBD on a crap day it's two hours each way. Seriously big drag on work life balance.
Good old Sydney traffic. How I don't miss it.
Ouch, I had mates at Windsor, its far, In Brisbane somwhere that far isnt even Brisbane any more, In fact its about where Gatton is in relation to Brisbane!
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
