Mugabetown - Whoretownin' At It's Worst.
Im fine with waiting, Im not overly fazed really.... Id rather it stay there a while longer and be done right than rush it for the weekend and take i to the track and break it lol..
Richard has high hopes for the build which is good.
3.2 stroker is definitely the go i reckon... Its probably the only new motor id move to from what im currently making
waiting...................tell me about it
I hate waiting... For anything... Let alone my car... A day is forever to wait to me...
I am hungry... Home time in 1hr and 12mins!
I'm experiencing nothing compared to your unfortunately turn of events Ants. Hopefully by what Haltech told you yesterday that the saga is coming to an end shortly. EFI to get your ECU back by the weekend hopefully
hopefully..........x all fingers that is accurate Scottie.
So's a puffer fish^^^ :)
HAHAHAHAHA - made me think of bloat...
Nemo, newcomer of orange and white, you have been called forth to the summit of Mt. Wannahockaloogie to join with us in the fraternal bonds of tankhood!
Love tha movie...
Love tha movie...
Shark Bait OW AH AH!!!!
Mel check out my build thread..................then you will know a little more about me and the R
Hope you have a spare 12 hours, as the build is a thing of beauty and a extremely well detailed build thread!
Already seen it, also what youve put on here about Haltech and it being sent off and the delays and boo :(
THE RING OF FIREEEE!
Well then....................scccwweeeettttt!!!! :thumbsup:
Tempted to call Haltech again but really CBF right now...............that my new mentality CBF!!!
its great :dry:
its great :dry:
Yeah will be good when you FINALLY GET THE FLIPPIN THING!!!!!!!!!!!!!
    • Yes. Get rid of that battery. It is dead. It will cause problems.
    • Don't assume too much when there is a voltage issue....if the battery is flat and the alternator not charging it is easy for the voltage to drop way low at the ECU due to the draw of stuff like coils, fuel pump etc Whatever you see at the battery with the motor off, it should be at least 13.8 with it running
    • I have been wondering if this is as simple as a voltage issue with the battery. Even on a charger, I can’t seem to get it over 11.8V on the terminals.    Unless the alternator has failed as well, that wouldn’t cause it to die in the middle of driving though.
    • I’ll give this a shot next time I’m able to wrench on it.    I was able to get my hands on a Haltech Nexus, so that should help with some of the more bizarre troubleshooting. Make sure the CAS is actually sending signal and will be able to set the proper dwell on the R35 coils.    I’ve checked power/grounds/signals at the CAS, ignitor, and plugs and it was all there. Granted this was static with ignition on, not cranking.    I also plan on swapping out the fuel filter and throwing on a fuel pressure gauge at the rail just to confirm I’m getting the correct pressure at the rail. 43psi if I recall correctly.
    • The attached document is fine. I just downloaded & opened it.
