Mugabetown - Whoretownin' At It's Worst.
Im fine with waiting, Im not overly fazed really.... Id rather it stay there a while longer and be done right than rush it for the weekend and take i to the track and break it lol..
Richard has high hopes for the build which is good.
3.2 stroker is definitely the go i reckon... Its probably the only new motor id move to from what im currently making
waiting...................tell me about it
I hate waiting... For anything... Let alone my car... A day is forever to wait to me...
I am hungry... Home time in 1hr and 12mins!
I'm experiencing nothing compared to your unfortunately turn of events Ants. Hopefully by what Haltech told you yesterday that the saga is coming to an end shortly. EFI to get your ECU back by the weekend hopefully
hopefully..........x all fingers that is accurate Scottie.
So's a puffer fish^^^ :)
HAHAHAHAHA - made me think of bloat...
Nemo, newcomer of orange and white, you have been called forth to the summit of Mt. Wannahockaloogie to join with us in the fraternal bonds of tankhood!
Love tha movie...
Love tha movie...
Shark Bait OW AH AH!!!!
Mel check out my build thread..................then you will know a little more about me and the R
Hope you have a spare 12 hours, as the build is a thing of beauty and a extremely well detailed build thread!
Already seen it, also what youve put on here about Haltech and it being sent off and the delays and boo :(
THE RING OF FIREEEE!
Well then....................scccwweeeettttt!!!! :thumbsup:
Tempted to call Haltech again but really CBF right now...............that my new mentality CBF!!!
its great :dry:
its great :dry:
Yeah will be good when you FINALLY GET THE FLIPPIN THING!!!!!!!!!!!!!
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
