Mugabetown - Whoretownin' At It's Worst.
The only person who knows what is going on is Sean. At the end of the day, he is a great tuner and hence why we have him on as a sponsor. He has a great deal of knowledge with these motors and also has a number of supporters. A lot of the people that use him speak greatly of what he does. However, not everyone uses him and anyone that has either built a car or required a major re-tune will tell you that these things take a lot of time.
I can appreciate that it is difficult from your end as you just want your car back. Although it's been 3 weeks since you delivered it to Sean, there has been a few things that have come up in that time.
1) the fuel pump
2) he fell ill for a week
3) Jambo - a massive marketing opportunity for him that probably results in a lot of revenue for his business
4) the ECU
The added difficulty is when you have people who haven't built a car before asking why it hasn't been done yet. You've got a brand new engine which is worth some decent coin along with some very nice go-fast bits, you don't want this rushed and botched.
My 2c, speak to Sean and try and maintain a positive frame of mind. :) I know that it isn't easy, but that's what you need to do.
Bunta and Colin had theirs tuned there and they were both quite nice and white and 32s and GT-Rs.... Creepy :P
Tony, hiscar has been there 6 weeks, not 3
My bad! Misread that as September. Either way, the best thing to do would be to discuss it with Sean in person. At this stage, other people asking questions could simply aggravate the situation.
Definitely my bad though!
Indeed :verymad:
exactly. It really makes u think how twice how they do business.........No such thing as good business ethics within this industry
There is you just have to get a mechanic that won't lie to you
Like... GST or total revenue, or Director's salary right? ;)
no. only if the transaction(s) in question is = or > 5% of the benchmark and also if the item is material by nature.........
majority of publicly and non-publicly listed corporations don't like it either.
Lucky for them I'm not an auditor........
LOL! Damn accountants following legislation. My accountant is also like that.
So martins car is back from the auto elecies.
Hopefully Tomorrow Jamie will give him a call and discuss what is being done and give him a quote, if we don't have a flat out day still have cars left over from Monday :/ why do hilux's have to be so crap
becauseToyota
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
